Order Ford 8N Parts Online
8N ? - lever under seat?
Richard Dorough
07-19-2006 04:37:36
What does the lever under the seat doand how do you work it?
Bruce (VA)
07-19-2006 05:38:50
 Re: 8N ? - lever under seat? in reply to Richard Dorough, 07-19-2006 04:37:36
It for draft/position control of the implements on the 3 point hitch. Up for position control, meaning that the implement will stay in the position you place it in w/ the touch control lever. Down for draft control when plowing; it lets the plow raise up if it hits harder dirt. Simple rule: keep it in the up position unless you are plowing. Of course, all of what I just said is dependent upon a properly adjusted & working system!
