Order Ford 8N Parts Online
8N once more
ron,ar
07-20-2006 16:51:51
I have almost finished my short term repairs on the 8N I brought home the 6th of July. I have it looking fairly nice, it starts (12V conversion) easy enough, idles good and throttles up fair. The lift works very well and it has good tires. There are two things I have concerns about. 1. Third gear is almost non-existant, it barely will go into third and unless I hold the shifter it won't stay engaged. I have had the cover off but didn't see anything obvious.
2. I said it throttles up fair...if I pull the throttle wide open quickly it sputters, engine goes to full throttle but the governor still "hunts" and the engine just does not run smooth, There is plenty of fuel supply, the float is right, the float bowl is at the right level when I removed the top.. I tore the carb back down again, recleaned, reassembled and tried every adjusting trick I knew of. I have the high speed adjusting screw out quite a ways to make it run best.I removed the dist again, re gapped the points, removed the centrifugal advance and saw nothing wrong there either. I adjusted the timing both with a straight-edge and then by ear and it did not solve the surging problem.If I move the throttle lever up to wide open slowly (one slow continious movement) it runs right. It only surges if I go into WOT quickly. All arts in the ign system are new, the carb been boiled out and cleaned and recleaned. I wish I had a scope to watch the secondary pattern. I saw no errant sparkies jumping around in the dark either. Any more ideas? I have not checked the Gov as someone here said that was not my problem. Thanks for any help.
Larry 8N75381
07-21-2006 07:04:17
 Re: different thought in reply to ron,ar, 07-20-2006 16:51:51
I am afraid that I have a MUCH different interpretation of where your problem is. You said, quote;
[snip!]
If I move the throttle lever up to wide open slowly (one slow continuous movement) it runs right. It only surges if I go into WOT quickly.
This sounds like a governor problem to me. By suddenly opening up the throttle, you create a situation in the governor that is undamped oscillation (like a car with bad shocks - it will continue "bouncing" up and down much longer than it should when you push down on a fender suddenly and release) so it "hunts" meaning that it is OVER CORRECTING in each direction, slow engine RPM - open throttle, fast engine RPM - close throttle. These happen fast enough to simulate what you did to start the "hunting" [undamped oscillation], but does not happen when you open the hand throttle slowly, because you have not forced the governor to over correct.
I would check your governor for a grove in the cup, or wear else where.
ron,ar
07-21-2006 07:12:50
 Re: different thought in reply to Larry 8N75381, 07-21-2006 07:04:17
Thanks, I kinda agree with what you said but it does not explain why I have to have my main adjusting needle out so far to make it run right at high throttle. I understand that no two are exactly the same but there is a lot of difference in mine and what most others have said theirs adjust at. I am going to reassemble my carb and take a hard look at both the intake and the governor. Thanks again.
Larry 8N75381
07-21-2006 10:48:45
 Re: different thought in reply to ron,ar, 07-21-2006 07:12:50
Aha!!! The two or more things wrong/not just as they should be situation. It looks like you have a carb problem that shows up as the jet adjustment. Then there is the "hunting" of the governor trying to give the engine just the right amount of fuel for the hand throttle setting.
Been "beat up" more than once trouble shooting computer problems that were two or more failures. They got really tricky when one failure was tied to another one so that the symptoms of one masked the other. Wish I had some good words of wisdom to help you. In my case, I usually had to resort to writing down what I did and what was the result, every step along the way, eventually a pattern would emerge that gave the solution.
Good luck, let us know what you find.
Larry
Bob
07-21-2006 14:03:11
 Re: different thought in reply to Larry 8N75381, 07-21-2006 10:48:45
"Stabilize" the governor's movement of the throttle rod to the carburetor by holding it still with your hand.
Governor problem... the engine will settle down, and with a very slight movement of the throttle rod, you will be able to maintain a steady engine speed.
Carburetor problem... the engine WON'T settle down at a steady speed with the throttle rod to the carburetor "stabilized" by hand.
Russ SoCal
07-20-2006 21:23:09
 Re: 8N once more in reply to ron,ar, 07-20-2006 16:51:51
Ron,
You can swap the main and economizer jets as both have 10-32 threads, but I don't think that's your problem. The main goes under the tube with the 3/8" nut on it and the economizer goes in at an angle off to the side. The idle jet is in the top half and has 8-32 threads. If my rememory is correct, the main has almost twice the hole size of the economizer.
Have you checked the spring on your governor? The one that's almost impossible to set at no slack and no tension.
Russ
third party image
ron,ar
07-20-2006 21:43:06
 Re: 8N once more in reply to Russ SoCal, 07-20-2006 21:23:09
I tried to swap jets but one looked bigger than the other. I will try it again tomorrow. I have not looked at the govenor. Thanksfor the picture, the one in my book is awfully dark for some reason, can't make heads or tails from some of them.
Phil (NJ,Az,Sask)
07-20-2006 21:42:16
[quote]If my rememory is correct, the main has almost twice the hole size of the economizer.[/quote]
I think he said that he put the smaller (hole) in to the MAIN jet location (under the nozzle) ...and that would be wrong!
JMHO
ron,ar
07-20-2006 21:57:34
 Re: 8N once more in reply to Phil (NJ,Az,Sask), 07-20-2006 21:42:16
When I said smaller, I was referring to outside diameter because one looked bigger than the other. I tried to swap places and the one did not want to start easy. It is waaaaay down in that hole and I didn't want to screw up any more than I already do. It does appear that most of you folks believe that the two jets are the same size outside so I will re-examine that aspect tomorrow. Heck, maybe I'll do i tonight, I can do it in my sleep I think. Thanks for the input guys :^)
ron,ar
07-20-2006 18:59:36
 same question with picture in reply to ron,ar, 07-20-2006 16:51:51
third party image
Ok, here is my question re-phrased,I have searched and read the archieves and read the repies about carb adjustment. I have a good understanding about the adjustments. I DO question my putting the main jet in the right place. Here is a picture from Don Stewarts article (a good one too) on rebuilding the Marvel carb. This picture shows the main jet somewhere in the rectangular hole in the lower housing. I put it in the same hole that the main nozzle goes. Did I put the jet in the wrong place or is this picture misleading? Thanks for the help guys.
ZANE
07-21-2006 03:34:29
 Re: same question with picture in reply to ron,ar, 07-20-2006 18:59:36
That is a good example of misleading information you sometimes find on the Internet. Sometimes it is just a well meaning mistake and sometimes a cruel joke.
Zane
Bob
07-20-2006 21:20:30
The picture is wacked out. The main jet screws down deep in the hole, and the nozzle goes on top of it.
ron,ar
07-20-2006 21:37:31
 thanks Bob in reply to Bob, 07-20-2006 21:20:30
That answers that. I was 90% sure I had that right but when I found that article and pictures my mind started to question itself :^)
Bob
07-20-2006 21:53:31
 Re: thanks Bob in reply to ron,ar, 07-20-2006 21:37:31
Here's a scan from an official Marvel-Schebler manual.
Third Party Image
I need to get a better scan. For now, I put the part names next to the unreadable key numbers, refering to the original copy, for the part names.
K.LaRue-VA
07-20-2006 19:22:51
Some of the carbs have a fuel limiting jet that goes under the main nozzle. But I believe the main jet should be what your Main Adjusting Needle bottoms out in after you put the two halves of teh carb together. The photo you posted looks like they are pointing at the opposite end of the carb from where the Main Adjusting Needle goes??? Now I'm getting confused. I rebuilt mine last fall but that is too far back to remember exactly what it looked like in there.
Tom N MS
07-20-2006 18:55:59
I like the way Dell explains the carb. adjustment.
It AIN'T how many turns that count in adjusting a carburator. Each carb and engine is uniquely different. Thats why thar's them handy-dandy fiddle screws on your carb. Can you tell the difference between the idle mixture and main jet mixture screws? Can you tell where the lowspeed idle set screw is? Can you tell which governor rod connects to the carb throttle shaft?
Ford Owners Manual sez to set BOTH the idle mixture and the main jet to 1 turn. Well that works on a new carb on a new engine. I don't think your tractor qualifies. Therefore, I suggest 1-1/2 turns for both the idle mixture and the main jet.
After you get your engine started and fully warmed up (about 15 minutes). Adjust the idle mixture for MAXIMUM rpms, not maximum smoothness, understand? max idle rpms. Tractor idle spec is 450 rpms which is awfull slow to our ears. If your carb is anywheres to being right, you can do it.
Now then, goose your throttle, if engine doesn't respond, enrich the mainjet 1/8 turn. Do it again. You may have to go out to 2 turns on main jet, but no more.
Learn how to read your sparkies color. After idleing for 15 mins, pull a plug, it should be a light tan or light gray color. If it is sooty black your too rich. If it is clean white your too lean. But most important, adjust idle mixture for MAX rpms. Now go mow or plow for a few minutes at high rpms, and pull a sparkie and read the color. That will tell you how well you've adjusted your main jet.
From the black art of adjusting carbs..... ...Dell
K.LaRue-VA
07-20-2006 18:40:08
Two adjustments on the carb work together. Both need to be set correctly in the proper order.
Start with both mixture screws about one turn out from lightly seated. Start the engine and adjust idle mixture screw (small screw near where carb attaches to the manifold) for smoothest low-speed (around 400 RPM) idle. You should adjust the idle mixture screw by slowly turning in until engine stumbles (too rich) and then turning out until the engine smooths out. You may have to back off the idle stop screw (the one where the linkage connects) if the engine speeds up too much after adjusting the idle mixture. If so, readjust the idle mixture screw.
This carb does not have an accelerator pump, so you want the idle screw set right at the point it smoothes out from being too rich, rather than centering between too rich and too lean, like you would do with most automobile carbs. If you set it too lean it will stumble like you describe when you quickly advance the throttle.
Only after you get the idle speed and mixture correct do you adjust the high speed mixture screw (large knob at the opposite end from the air inlet). In a perfect world you rev the engine up to rated speed (1500 RPM or about 3/4 throttle) with a good load on it and turn the screw in until it stumbles then back off until the engine smooths out. I don't have any way to do that safely, so I start with the bench setting and adjust by turning the screw in 1/8 turn at a time and putting a load on the engine. As soon as I detect any stumble, hesitation, or backfire when picking up load, I turn the screw back out 1/8 turn and then leave it alone.
CENTAUR
07-20-2006 17:34:21
When you open the high speed adjustable needle screw it should become too rich so that it runs rough.If it does not that that has to be corrected.LEN
ron,ar
07-20-2006 18:30:07
 Re: 8N once more in reply to CENTAUR, 07-20-2006 17:34:21
That is the part that bothers me. If I remove the main screw completly it runs good. I have to believe that I have something wron in the carb but I do not know what it would be. I can"t see the diagram in my book plain enough to see where exactly where the smaller of the two jets go. I know where the larger one belongs but when I reassmebled it I forgot where I removed the smaller one. I screwed it into the deep hole where the hollow tube with a hex head goes. Is that the right place? My book has the poorest picture.
souNdguy
07-20-2006 20:10:32
 Re: 8N once more in reply to ron,ar, 07-20-2006 18:30:07
Didn't swap idle and main jets did ya?
Any vacume leaks? It might be continually lean..
Soundguy
ron,ar
07-20-2006 20:30:59
 I thought of that in reply to souNdguy, 07-20-2006 20:10:32
third party image
Idle and main jets are not the same size externally. I am confused by both the picture I posted concerning the location of the main jet and also the folowing statement in Don Stewart's article: "Next to the float seat is the idle jet seat. This is the jet into which the idle screw/needle fits when the carburetor is running on your tractor" Knowing that the idle mixture screw is installed from the right side of the carb makes that statement confusing. Actually the tractor runs pretty good with the high speed screw out about 6 rounds but I am the kind of guy that wants to know why mine has to be out so dang far to make it right.
souNdguy
07-20-2006 20:46:34
 Re: I thought of that in reply to ron,ar, 07-20-2006 20:30:59
Out that far is alot of enrichment... Makes me think mainjet clog.. fuel source obstruction, or a WAY lean condition due to leaking gaskets or a cracked casting... ( manifold crack.. manifold gasket.. carb to manifold gasket.. carb halves gasket.. etc.
Try the propane or ether trick to check for vacume leak...
The fact that it doesn't seem to be running rich with the main needle out that much means that it either isn't getting all that fuel due to the clogged jet or the obstruction.. or that the mix is so lean.. that it needs that much enriching to work ok.. that's my uneducated guess and 2 cents anyway...
Soundguy
ron,ar
07-20-2006 20:57:45
 no main jet clog in reply to souNdguy, 07-20-2006 20:46:34
I had that carb apart again today, re-cleaned and used compressed air on all passages. I sprayed carb cleaner thru all the passages including the idle and main circuits. Everything is open. I am leaning (no pun intended) toward a too lean mixture from a vacuum leak. Manifold is the only source I have not examined. New gaskets on carb halves and carb to manifold. I also resurfaced the carb halves by using a sheet of sandpaper on a sheet of glass. They are true. Gaskets seal good and I changed throttle shaft seal. I'm missing something here but I can't see it. I've had less trouble rebuilding Allison automatic transmissions :^(
souNdguy
07-20-2006 21:10:19
 Re: no main jet clog in reply to ron,ar, 07-20-2006 20:57:45
Use propane torch (unlit) wd-40 or start fluid, and start tractor, and hose down the manifold to block areas.. see what you get.
Very ocasionally I get debri that the spray carb cleaner won't cut.. but the dip style cleaner cuts easilly.. though I'm sure you've cleaned it good... just mentioning it.. etc.
Soundguy
ron,ar
07-20-2006 21:35:18
 yep in reply to souNdguy, 07-20-2006 21:10:19
I soaked her overnight in a new tub of gunk. That stuff has not gotten any better smellin either, ya still have to wear it off, no amount of soap and water will rid you of the odor. Gnight folks, thanks for the ideas.
souNdguy
07-20-2006 21:40:15
 Re: yep in reply to ron,ar, 07-20-2006 21:35:18
Yep.. I use the chemtool dip.. and it not only eats yer skin off.. but as you point out.. makes ya smell bad for days on end..
Soundguy
Dixon
07-20-2006 22:00:21
 Re: yep in reply to souNdguy, 07-20-2006 21:40:15
now I'm gonna throw my 2 cents worth in.I'm sorry I didn't see or here what your problem is but useing Gunk carberator cleaner won't help you.I've used it and you could leave a carb in there for a week and still have dirt.Go to NAPA and tell them you want some of the good stuff,Its not cheap but it'll clean her.oh and if shes still not fixed restate the problem and let everyone hash it over again I have faith these guys will figure it out.
souNdguy
07-20-2006 22:35:56
 Re: yep in reply to Dixon, 07-20-2006 22:00:21
I use the chemdip myself. Takes paint of instantly, disolves rubber in seconds.. starts eating plastics on contact... turns skin white in about 5 minutes.. and leaves a smell kinda like kerosene for hours to days afterwards..
soundguy
