thanks flathead
ron,ar
07-21-2006 10:51:01
That confirms my own findings. I will look for a vacuum leak around the manifold later today. I will post the results. Thanks again.
flathead
07-21-2006 11:02:28
 Re: thanks flathead in reply to ron,ar, 07-21-2006 10:51:01
Another place to check for a vacuum leak is the throttle shaft. A drop or two of heavy oil (like gear oil) can momentarily seal up a vacuum leak between the throttle shaft and bushing and help confirm or eliminate this location.
best of luck.
flathead
K.LaRue-VA
07-21-2006 12:32:50
 Re: thanks flathead in reply to flathead, 07-21-2006 11:02:28
How rotten is your manifold? It is possible, since this is all one casting, that you may have an internal crack or corrosion that has joined the intake and the exhaust. This could cause very strange things to happen.
