Radiator cap
Richt
07-24-2006 09:22:39
I bought a used 9N radiator on ebay.It's in excellent shape but the radiator filler neck is different than the previous radiator that was in my 2N and the cap wont work. The radiator filler neck is set up to like a fuel tank where the cap hooks to the inside of the neck instead of hooking on the outside of the neck. Anyone know where I can get a radiator cap to fit this? I am currently using a ford fuel cap that fits but I know can't hold pressure plus it dosen't look very nice.
Richt
07-27-2006 04:04:59
 Re: Radiator cap in reply to Richt, 07-24-2006 09:22:39
Still looking for this and I have to believe someone has one sitting on the shelf. This is the early style cap that is not in reproduction. Please help me out! Doen't need to be pretty just complete.
Chad from Michigan
07-24-2006 09:54:36
Richt
I have a brand new cap that will fit your tractor and you have the one I need you wanna trade?
email me
Chad
Duffy8N
07-24-2006 09:48:01
Look at some of the CHAD in MI requests. It sounds like you have an unpressurized early 9N.
I used the "gas" type cap, and drilled out the 2 spot welds on an after market wing type cap I had around. Then I JB welded it, (making sure it was in the coorect tight position), and walla. Or you can buy one like Chad did. Just an idea.
