Order Ford 8N Parts Online
8N will not start
SHADY LADY
07-26-2006 07:01:11
I recently put a set of rings in my 8n it seemed to be smoking a little. But I can't seem to get it to start after I reassembled it. I have a very strong spark and I seem to be getting fuel. Any other suggestions or ideas would be appreciated.
souNdguy
07-26-2006 08:49:48
 Re: 8N will not start in reply to SHADY LADY, 07-26-2006 07:01:11
Do you have it timed correctly?
Does a thumb over the spark plug hole produce compression as the cyl is on a compression stroke ( valves ).
If you think all is as it should be, and it is getting gas, and has spark, pull the plugs and att a tablespoon of engine oil to each cyl, roll the engine over a rev or two, then reinstall the plugs and plugs and let her rip.. use choke to help start.. but don't flood.
A brief shot of start fluid may be usefull. once she fires put her to work setting those rings..
Soundguy
