Order Ford 8N Parts Online
51 8N PTO
popbreed
07-31-2006 21:17:35
Was going to replace the seal on the PTO due to leakage. Removed the unit and find the collar on the shaft is not pressed against the bearing. Question, can I press it on further (approx. 3/8" gap between it and bearing). Do I heat it? The collar on the opposite side of the bearing appears to be part of the PTO shaft, correct? Should I buy a new collar and start over? Thanks for the help.
popbreed
08-01-2006 18:51:29
 Re: 51 8N PTO in reply to popbreed, 07-31-2006 21:17:35
Zane, I woudered about that. Beaing is now captured between tyhe two sleeves and I have 2" of spline beyond the back collar. I will rty the ORC and see if the hole lines up. Thanks
Bob
07-31-2006 21:22:22
I'd clean up the shaft in the gap area real well, then coat it with Loctite High-strength Bearing and Sleeve Retaining Compound, and press the sleeve fully in place, COLD.
popbreed
08-01-2006 07:06:35
 Re: 51 8N PTO in reply to Bob, 07-31-2006 21:22:22
Thanks Bob,
I Will do as you suggest. I plan on holding against the front sleeve when I press the rear sleeve. OK?
ZANE
08-01-2006 18:31:10
 Re: 51 8N PTO in reply to popbreed, 08-01-2006 07:06:35
Better be sure which sleeve has slipped. Don't want to cause the PTO shaft to be too far back or forward.
Zane
