Order Ford 8N Parts Online
51 8N rear axle seals
popbreed
08-01-2006 18:57:23
Have ordered new seals as right side is leaking. I understand the 8N has the additional seal inboard of the outside bearing plus the seal on the outboard side of the bearing. How does the bearing get lubrication from the center housing? The bearing does NOT have seals. Simnce the seals are leaking, it is well lubricated now but what happens with new seals? Is the bearing wrong? This forum is great! I have learned much just reading every day. Thanks
JohnMD
08-02-2006 04:25:51
 Re: 51 8N rear axle seals in reply to popbreed, 08-01-2006 18:57:23
Pack the bearing with grease.
popbreed
08-02-2006 07:25:42
 Re: 51 8N rear axle seals in reply to JohnMD, 08-02-2006 04:25:51
Thanks for the reply. I will pack them with the old fashion "stringey" wheel bearing grease.
