Order Ford 9N Parts Online
9N without Ferguson system?
rick merwin
08-02-2006 22:06:43
My tractor looks like a N9... but I find no numerals on the block where the serial # should be, and even more mysterious, there are no hydrolics or pto and the drawbar is fixed. The cover of final drive case lacks the lift arms & lacks the castings for upper attachment!!! (These have not simply been removed...)Were there 9N's without the Ferguson system? Could this have been a military tug or non-ag tractor?
Tim...Ok
08-04-2006 04:15:25
 Re: 9N without Ferguson system? in reply to rick merwin, 08-02-2006 22:06:43
third party image
thats the first like this I've seen,very cool
Scott PA
08-03-2006 18:22:11
Check for a transmission serial# on the top of the flange at the junction of the rear of the trans. and the front of the center rear housing, some 1940's had this and is close to the engine serial#, the key switch location will help date it also.
souNdguy
08-03-2006 06:08:35
Post some pics of that bad boy. We love to see non standard ( or rare low production units.. especially ones that little documentation exists on. )
Soundguy
rick merwin
08-03-2006 14:53:42
 Re: 9N without Ferguson system? in reply to souNdguy, 08-03-2006 06:08:35
Picture posted in gallery.
souNdguy
08-03-2006 20:20:07
 Re: 9N without Ferguson system? in reply to rick merwin, 08-03-2006 14:53:42
Why not add a link to a message so that everyone can find them without hunting for them.
Soundguy
KCM
08-02-2006 22:19:20
Moto-tugs did not have a lift or hydraulics or PTO, and the lift cover is as you describe. They did have hydraulic brakes though. Also, years ago I saw brochures of a 1940 or 1941 9N that also was stripped down as you say and was used as a tow tractor. It was before the Moto-tug and looked like a stock tractor without the options. It did have some kind of heavy framework that went from front to back, and was a Ford produced model. Maybe that is what you have.
As far as the serial number, I would suspect a combine or other engine has been installed in the past.
rick merwin
08-03-2006 15:17:54
 Re: 9N without Ferguson system? in reply to KCM, 08-02-2006 22:19:20
Stripped-down production model 9N? How cool is that? My wheel/axle attach w rivits.. fits your date range of '40-41. Simplified casings are factory rather than modified/removed...Thanks for your help! peace,rick
