Order Ford 8N Parts Online
8N coil installation
PeP
08-05-2006 17:33:30
replacing my old 6 volt coil that had one post labeled BAT-and nothing marked on the other post that went to the dist.-the replacement has + and -.Which one goes to the dist now? Does it matter?
Bruce (VA)
08-05-2006 18:13:24
 Re: 8N coil installation in reply to PeP, 08-05-2006 17:33:30
Yes, it does matter. Plus Positive to Points (PPP). If it's a positive ground, which it should be if it's 6v, the plus side of the coil goes to the distributor. My last electronics theory class was in 1967, taught by a Urkranian immigrant who counted in German, swore in Italian & spoke very little English; the theory as to why the spark will be hotter if you maintain the correct polarity is interesting..... but I forgot it. All I I remember is that you should not reverse the polarity!
PeP
08-06-2006 09:33:54
 Re: 8N coil installation in reply to Bruce (VA), 08-05-2006 18:13:24
Thanks!
souNdguy
08-05-2006 21:59:50
Eddison effect... Or 'thermionic emmision'.. for the new fangled people...
Soundguy
