Order Ford 8N Parts Online
8n points/distributor
48ford 8n
08-08-2006 09:24:51
When replaceing my points I noticed that the copper strip that carries spark from the condender to the points was cracked. Need less to say it broke. The copper strip is rivited to the distributor and the other end screws on to the points.. Is there a replacement repair kit for this? Can I just run the condenser lead right to the points screw?
Colin King
08-08-2006 09:46:13
 Re: 8n points/distributor in reply to 48ford 8n, 08-08-2006 09:24:51
If I'm understanding correctly, I think a similar problem was discussed a couple of days ago. Here's a link to that discussion - hope it points you in the right direction!
Colin, MN
Bob
08-08-2006 09:42:35
For a SIMPLE repair, run a length of insulated primary wire (16 GA should work) from the special screw facing upward on the breaker plate, to the breaker points.
That screw, which the "spring thingy" at the base of the coil sits on, the condensor, and the breaker points MUST all have a common connection for the system to produce spark.
Also, some breaker point sets have a copper strip that parallels the steel spring. If you have an old set up points like that, you can use the copper strip to make a replacement for the broken strip.
That being said, for this application, there is nothing "magical" about the OEM copper strip, and, electrically, the insulated wire I first suggested will perform equally well as replacing the copper strip with a new one.
Or, if all of this is frustrating, you can get a complete new breaker plate from one of the "N" parts suppliers that will include the copper strip.
