Not all Gas is Created Equal?
Col Bob
08-09-2006 08:31:55
I had an issue with my valves sticking. With the Forums help and a lot of MMO, the 1940 9N is running. Someone mentioned that one of the caused for valves sticking could be the type of gas. That so, I have a few questions.
What is the right type of gas and what should I add to it - non-oxygenated gas with MMO?
Do I need to add MMO or a lead substitute?
Do I need to but in a high octane (more than 87)?
If the Tractor sits for months at a time do I also need to fog the cylinders?
Could these gas related observation have anything to do with sticking valves”
There is a varnish like substance that forms on the sediment bowl
There is the gray sludge in the bottom of the sediment bowl
Thanks
tim[in]
08-10-2006 10:08:32
 Re: Not all Gas is Created Equal? in reply to Col Bob, 08-09-2006 08:31:55
what about cut outs, i always wanted some for my 64 impala but then i couldnt find them.could really have a lot of fun with those. at least drown out the boomp a boom of car beside you!! lol as for hot gas, you can always buy racing gas.
souNdguy
08-09-2006 08:42:05
87 octane is fine.. the gas, when your tractor was built was much lower.
No lead addatives.. they aren't needed.
if you store gas.. use a stabilizer.. like stabil.. helps prevent fuel decay and varnish.
A can of fuel system cleaner and drier every now and then sure won't hurt.. even if it don't help much.
I wouldn't fog anything if I used it a few times a year..e tc.
I use MMo periodically.. can't hurt.. seems to help..
That's mostly opinion.. but's been doing' good for me for years.
Soundguy
RP-40-9n
08-09-2006 18:15:41
 Re: Not all Gas is Created Equal? in reply to souNdguy, 08-09-2006 08:42:05
if you have this problem it would be wise to turn your fuel flow off and let tractor run till engine dies, especially for longer no run periods. like you would do a boat motor.
souNdguy
08-09-2006 18:31:46
 Re: Not all Gas is Created Equal? in reply to RP-40-9n, 08-09-2006 18:15:41
i do that as standard procedure...
Soundguy
Col Bob
08-09-2006 09:28:52
I will add some stabilizer.
Thanks
Cargocult
08-09-2006 09:39:37
 Re: Not all Gas is Created Equal? in reply to Col Bob, 08-09-2006 09:28:52
Gas these days ain't like it was back in the Good Old Days! For many reasons..mostly environmental & gummint, fuel is really suck these days! (If u can find/afford it, that is, hehehe) I have a vehicle that needs Premium Gas 2 run, and the Premium these days is a Pale Imitation of the Premium Go-Juice back in the days the car was built!!
ron,ar
08-09-2006 16:16:19
 two things please CC in reply to Cargocult , 08-09-2006 09:39:37
#1-How about you post the photo of that big sled you have, you know the one, from back when they made REAL cars.
#2- Post your plans/photos for the N-series tractor jack, folks been asking about them and your name keeps coming up.
Cargocult again
08-09-2006 16:52:36
 Re: two things please CC in reply to ron,ar, 08-09-2006 16:16:19
third party image
You mean my nice 1967 Pontiac Gradn Prix?? 15 MPG, if I keep my foot outta da 4 barrell!! My tracjack plans are on my Geocities Website! CC
old 9
08-09-2006 18:21:18
 Re: two things please CC in reply to Cargocult again, 08-09-2006 16:52:36
Reminds me of my 1965 Ford .Top down, Great on a warm summer's night. joe
Cargocult yet again
08-10-2006 07:38:05
 Re: two things please CC in reply to old 9, 08-09-2006 18:21:18
"Top down, Great on a warm summer's night"..Yep!!
Dual exhausts blatting on the pavement, acres of shiny sheet-metal out in front of u!! The gentle rumble of Good Honest American V-8 Power! (Soemthing the newfangled Japjunkers can only dream of) These are things worth dying 4!! And, to add icing 2 d cake..it is cheaper than driving a newfangled autymobile!! Nuff Sed!! Good luck with ur 65 Ford!! They had great styling!!
