Physical wiring diagram attached!
SCgoatfarmer
08-09-2006 11:10:18
I got the right voltage regulatro today.
The field connection of the generator goes to the F on the regulator. The armature connection of the generator goes to the A on the regulator. The ground on the generator goes to the ground slot and the B on the voltage regulator should go to the ammeter loop. Correct?
Phil (NJ,Az,Sask)
08-10-2006 13:47:10
 Re: Physical wiring diagram attached! in reply to SCgoatfarmer, 08-09-2006 11:10:18
SCGoatfarmer, You done right! Using that other Alterator regulater would be wishful thinking on my part.
Yes your wiring is correct. The ammeter has the battery side (wired to battery) and a Battery "load" side(ignition switch/lights/Reg. The only function of the ammeter is to indicate current flow to or from the battery.
Hope this Helps,
