Order Ford 8N Parts Online
8N Frontmount
123qse
08-11-2006 16:57:49
I can see that I will have to check through my electrical system before I get going again. I have to confess that I have been short cutting and clipping two wires together to start my tractor. I need to get a new switch. What is the deal on wiring the switch? I have basically three wires-what are they/
Also can I check to see if a charge is going to my coil by simply taking off the wire and touching it to the block to see a spark? As someone said, my starter can go, as it does, but perhaps nothing is going through the ignition system! Bob---Down to the 30's tonite-already here in August and my firewood is not up to the house from the woods.
Bruce (VA)
08-11-2006 18:05:19
 Re: 8N Frontmount in reply to 123qse, 08-11-2006 16:57:49
6v or 12v? Lot's of places carry replacement switches (this board sells them), or you can get a marine toggle switch instead. Easy to install. A replacement switch will screw right in the same hole. Checking for spark by grounding the wire to the coil to the block doesn't tell you much; a multimeter is about $16 at Wallyworld & is a very useful tool. If the tractor has old & frayed wires, it might be time for a rewire job. In addition to the new wires, you will see a lot fewer problems over the next few years because you will be cleaning all the grounds as you replace the wiring harness. Easy job; 2-3 hours max, including beer breaks.
123qse
08-11-2006 19:19:21
 Re: 8N Frontmount in reply to Bruce (VA), 08-11-2006 18:05:19
This is a 6 volt sys. Wiring looks good. Dist wires are last year's.Almost Nothing in the ignition system is more than two years old. Bob
