First of all, Congrats on the building of your home. There is nothing in the world like making something from nothing. And consider the life that will be in there for generations to come. To answer your question: I had to grade 2 acres about 3 years ago. First I used my cultivator to go through and break up the (dry) soil even more. Then I hit it with my 3pt blade with a wood header tied to the back of it length-wise with as many bricks as I could fit in it. It worked like butta. Surely a box blade would be the cat's meow, but I was on a budget and had to use what I had on hand. If you have any trees in the area, make sure to mark around the drip line so the excavator doesn't enter that area and do a ton of damage to them. However, I did that and it didn't really matter to the guy I hired to do my leech fields. He was a butcher- roots, branches, whatever it took to get in and out in the easiest and quickest way. In 3 years I've had to cut down 8 trees in that area- 3 100 yr old oaks, and many more are on the way out. Oh yeah, not sure how it is in your area, but if you classify one of your bedrooms as a study or a library, in my part of OH, you reduce the required linear footage of your leech field. Wish someone had told me that ;) Sorry for the rant! Good luck and enjoy the work. -Chad OH P.S. Don't forget to take lots of pictures and video. You won't regret it.
