Order Ford 9N Parts Online
need help with serial numbers with 9n or 2n
antster
08-12-2006 19:15:53
Hello, just trying to figure out what I have here. I have my grandfather old trator that is either a 9n or 2n. I'm just a little lost with the serial number. This is what it read on the block,(stamp) *9n 75*, and it has a freeze plug on the left side in the center, A book I have says that this didn't happen until 1940 but one guy told me that this is a 1939 block.
Scott PA
08-13-2006 18:29:13
 Re: need help with serial numbers with 9n or 2n in reply to antster, 08-12-2006 19:15:53
Does it have a push starter button on the left side of the dash and a key switch on the right side of the dash and what number is stamped in fron of the steering wheel in the middle of the dash and a snap in hood battery lid?
d thomas
08-13-2006 17:06:34
antster, from what I gather from the number you give and the info given on John Smiths site I take it that you have a 1939 9N very close to the beginning of production. Number 75 to come off the assemble line. By this being what his site states::::: 1939 Serial number 9N1 - 9N10275
d thomas
08-13-2006 05:54:59
Go to John Smiths 8N site and go to the identify your tractor tab. Hope this helps. Link
Ross Pugh(NC)
08-13-2006 03:30:28
Looks to me like you have a 1941 9N= 1941 ser #'s began with 45976 and 1942 began with 88888. Therefore I would say yours is a 1941, wouldn't you?
antster
08-13-2006 11:04:04
 Re: need help with serial numbers with 9n or 2n in reply to Ross Pugh(NC), 08-13-2006 03:30:28
Do you think that this could be the last tractor to come out in 1940. Since the last number is 45975 and my serial number is *9n75*?
old
08-12-2006 19:25:33
Look on the left of this page under research &info then click on ford then on 9N etc and look up the number there. It will tell you what year engine it is if not what year tractor
antster
08-12-2006 19:38:00
 Re: need help with serial numbers with 9n or 2n in reply to old, 08-12-2006 19:25:33
thanks, but what do you think about the freeze plug issue?
old
08-12-2006 19:46:49
 Re: need help with serial numbers with 9n or 2n in reply to antster, 08-12-2006 19:38:00
I have no idea aboutthat and have never even looked on one to see what years did or din't have them
