what did I do? My simple tune-up
PeP
08-13-2006 16:24:00
I changed point/condensor/coil[+ side to points]-etc-than flipped my toggle switch on--and started cranking my 1950-6 volt + grd- side dist 8N.It was running just fine 2 weeks before.Of course it wouldn't fire at all and as I glanced down I saw I forgot to put back my shiny rotor.Well I did pop it back in and now it still won't fire.I took one of the connected plugs and laid it on the head to do the blue flame check-no sparky at all.Iv'e got a simple on/off toggle for an ignition switch and it's been fine for years.When I switch it on the amp gage shows discharge so I assume the switch is working--right?It acts just like the switch isn't in the ON Position.Can I by-pass some things to see what's bad?-PeP
K.LaRue-VA
08-13-2006 21:39:37
 Re: what did I do? My simple tune-up in reply to PeP, 08-13-2006 16:24:00
The no.1 reason for no spark at all after changing points and condenser is inadvertently grounding the terminal where the coil wire connects to the condenser and the spring-loaded terminal for the points. Double check that the spring-loaded contact for the points lands on the insulated terminal, and neither the spring nor the wire from the coil or condenser is going to ground.
The no.2 reason may be a shorted condenser. Sometimes they are bad right out of the box. Replace the new condenser with the old one and see if that fixes it.
old
08-13-2006 16:30:21
Pull the center wire off the cap and hold it close to the block and turn on the switch and turn it over. If you have saprk there the you probably have a bad cap/rotor. If you don't then run a hot wire from the battery to the coil and try for spark again. If you have spark then you have a problem with the switch or a wire going to the coil. If you still don't have spark you have a problem in the distubutor and you may have the points set wrong. On side mounts you set them a .025
PeP
08-14-2006 07:19:35
 Re: what did I do? My simple tune-up in reply to old, 08-13-2006 16:30:21
My local 8N parts guy said to check the resistor inside[left side when sitting]on the dash? The only thing I see is my terminal board and V-Reg.he said to jump accross it? Maybe he meant the T-Board?---PeP
old
08-14-2006 08:57:53
 Re: what did I do? My simple tune-up in reply to PeP, 08-14-2006 07:19:35
I'm not sure but I don't think the side mount had that resister and if it doesn't you can't jumper around it. But if you hot wire it from the battery to the coil even if its there you would be jumpering around it which is the thing I would do.
Pep
08-14-2006 12:49:07
 Re: what did I do? My simple tune-up in reply to old, 08-14-2006 08:57:53
Yep-no resistor--I'll just go step by step checking where the voltage stops!-Thanks--PeP
PeP
08-13-2006 16:41:22
Thanks--I'll try that-yes I do set the plugs and points at .025--PeP
