leaking carb
9NinVA
08-14-2006 04:32:44
Hello All,
I have a 9n that has a leaky carb. As soon as I turn on the gas it leaks from the bottom of the carb. I just had it rebuilt a little while ago but the lead is pretty bad. Any ideas on what to do? Rebuild again? Thanks
JohnMD
08-14-2006 04:39:06
 Re: leaking carb in reply to 9NinVA, 08-14-2006 04:32:44
Sounds like the float is stuck. Tap it with a screw driver. That may un stick the float. If it continues you will need to take it apart to see why the float is sticking.
9NinVA
08-14-2006 05:07:16
 Re: leaking carb in reply to JohnMD, 08-14-2006 04:39:06
I have tried to tap lightly thinking it was something like that and it didn't work. I haven't taken apart this type f carb before. Any place I can get some sort of diagram of this for free?
old
08-14-2006 09:35:30
 Re: leaking carb in reply to 9NinVA, 08-14-2006 05:07:16
You probably got so junk in the needle area of the carb and its not letting the needle seat so it can stop the gas when it should. These carbs are very simple but if you still need a picture I can probably scan a carb rebuilt instruction sheet and send it to you if you send me an e-mail
9NinVA
08-15-2006 04:43:16
 Re: leaking carb in reply to old, 08-14-2006 09:35:30
Thanks. I;m going to try these.
