Order Ford 8N Parts Online
Conversion Kits to 12V on 1948 8N
Alan Benoit
08-14-2006 08:39:00
When you Install a 12 Volt Conversion kit with alternator is the Battery still Pos Ground or does it become Neg Ground????
old
08-14-2006 09:39:34
 Re: Conversion Kits to 12V on 1948 8N in reply to Alan Benoit, 08-14-2006 08:39:00
Has to be switched to - ground and if you don't the moment you hook up the battery you will fry the new alterntor. Guess how I know how fast one will fry, yep hooked one up + ground and the alterntor smoked before I could even think about pulling the cables off.
Jack-Illinois
08-14-2006 09:06:54
Battery goes negative ground - reason - you can't polarize an alternator and get it to change polarity like you can a generator. Although a few positive ground alternators were made, they are not the type you are going to buy to put on your "N"
Bob
08-14-2006 23:08:19
 Re: Conversion Kits to 12V on 1948 8N in reply to Jack-Illinois, 08-14-2006 09:06:54
Jack,
I don't know where you've been, but don't rule out the possibility of a (+) ground alternator, such as a Delco 10SI.
Rebuilts are readily available with aftermarket regulators and rectifiers in 6-Volt (+) or (-) ground, and 12-Volt (+) or (-) ground.
I occasionally do see a 6-Volt (+) ground alternator installed on an older tractor, or a classic vehicle.
Therefore, never say "NEVER", until confirming what setup someone has come up with!
NICK D
08-14-2006 09:06:45
The 12V alternator will require negative ground.
