runs rough
Alan Shaw
08-14-2006 19:31:17
I have a 48 8nand I have noticed that when the gas gets below half it will start to sputter, run rough and die. I have tried to loosed the gas cap to see if was a vapor lock, but no luck. It seems like the extra gas pressure of a full tank helps it run better. Has any one seen this before?
JoePilot
08-14-2006 21:35:05
 Re: runs rough in reply to Alan Shaw, 08-14-2006 19:31:17
Or, it could be the hidden screen in the carb inlet elbow. Before you drain the tank, just loosen the connection at the carb (put a bucket under it first). If you get a good "kid pissin' on a rock" stream there, the problem's not in the tank. Pull out that screen and see if it is gunked up (like mine was:-) WD40 works to dissolve the gunk. Bang the end on a piece of wood to knock it out.
Joe
old
08-14-2006 19:52:33
Yep most of the time that means the screen in the tank is clogged with rust etc. You need to drain the tank which might be fun because of the problem. The remove the sediment bowl assembly from the tank and clean it up or replace it.
Alan shaw
08-14-2006 19:56:06
 Re: runs rough in reply to old, 08-14-2006 19:52:33
Sounds good I will give it a try.
Thanks
