Another Question-what didI do/ my simple tune up
PeP
08-16-2006 07:23:08
My original question on 8/13-probably is on pg 4 by now -resulted in a number of tests and still no spark from coil which I laid on the cyc head.I next ran a direct wire from the batt neg side to the neg post of the coil--again no spark from the coil lead to the dist.I put a volt meter in between the wire I just ran from the batt to the coil and got nothing? Shouldn't it read someting?I lighted out the ignition switch,it was OK--I bypassed the ign switch still nothing. What can I bypass or try next?--PeP
old
08-16-2006 08:25:37
 Re: Another Question-what didI do/ my simple tune in reply to PeP, 08-16-2006 07:23:08
Check/bypass the insalator going in to the distubutor. I've seen them shorted out there and if so you will have no spark and that problem is a bear to find if you don't know about that being a problem. I've seen whole distubutors replaced just because of that 2 bit part being bad. Also check the side to side slop in the distubutor shaft because if there is any it will cause the points not to work no matter how you set them
Tom N MS
08-17-2006 04:18:14
 Re: Another Question-what didI do/ my simple tune in reply to old, 08-16-2006 08:25:37
O thought it was front mount so I was talking about the insulator where the concave screw for the springy thing goes through the breaker plate. Can these be found without buying the whole plate? Thanks
Tom N MS
08-17-2006 04:15:13
Where can you but that 2 bit part separately??My Dad had to make one from a milk Jug...Might be good to have the right thing on hand.
PeP
08-16-2006 10:31:47
I think my problem isn't on the Dist side of the coil[yet]--I'm trying to figure why putting my volt meter between the Bat[neg] and neg coil post that I'm not getting any juice?I've got a pos grd side mtg dist--8N28483 newer 1950 model.--PeP
old
08-16-2006 11:08:04
 Re: Another Question-what didI do/ my simple tune in reply to PeP, 08-16-2006 10:31:47
Well if the place I'm talking about is short you will not get any reading because its shorting the power right to ground.
PeP
08-16-2006 13:09:34
 Re: Another Question-what didI do/ my simple tune in reply to old, 08-16-2006 11:08:04
I 'm having trouble understanding which insulator by the dist am I looking for?--PeP
old
08-16-2006 13:49:12
 Re: Another Question-what didI do/ my simple tune in reply to PeP, 08-16-2006 13:09:34
Its where the wire goes in the side of the distubutor and on the inside hooks up to the points. Another way to say it is the wire from the coil goes to a small bolt on the side of the distubutor and theres an insulater there and thats the one I'm talking about. They go bad and the bolt shorts on to the distubutor and reall causes you to go crazy tring to figure out why you don't have spark
PeP
08-17-2006 05:42:48
 Re: Another Question-what didI do/ my simple tune in reply to old, 08-16-2006 13:49:12
You know--- I'll betcha that's where the problem is--I'll take apart and clean everything up this Saturday--and let you know.--PeP
Bob
08-16-2006 07:28:58
Late 8N, side-mount distributor, right???
With the igntion switch "ON", using a test light with one lead grounded to the chassis, the (-) terminal on the coil should have powere.
The (+) terminal on the coil should show power if the breaker points are open, no power if the breaker points are closed.
PeP
08-16-2006 11:05:27
 Re: Another Question-what didI do/ my simple tune in reply to Bob, 08-16-2006 07:28:58
I forgot to check if my Points were open or closed--maybe that's why I don't have a completed circuit--sorry for all the dumb questions.--PeP
PeP
08-16-2006 10:36:14
I haven't been able to record any voltage to the Minus side of the coil yet.--now I got to check my by-pass wires Ive clipped in sections--I'll just keep backing up to find where it's open?--PeP
