2N generator wiring diagram
playfarmer
08-17-2006 13:42:33
My son and I are restoring my Dads old 2N. The wiring is a mess. It has a generator with one wire and a screw the can be adjusted for high and low. It has a relay under the battery and a coil or resister on the inside of the dash. What is the proper way to wire all this up? I got it to start last night but didn't even try to wire in the generator.
THanks you all for being such a good help.
Empennage
08-17-2006 14:28:12
 Re: 2N generator wiring diagram in reply to playfarmer, 08-17-2006 13:42:33
Try this site too. It's really super. The people here on YT site are the best too. Good luck with your project!
Empennage
08-17-2006 14:26:25
Here.
JohnMD
08-17-2006 14:49:09
 Re: 2N generator wiring diagram in reply to Empennage, 08-17-2006 14:26:25
There is nothing wrong with the wiring diagram above but I tap the head lights to the other side of the ignition switch to stop from having so much current run thru the switch.
