Zenith Carb.
Richard from SE
08-21-2006 10:51:04
I have a chance to acquire a zenith carb VERY reasonably. Do they work any better on N's than the original marvels ? If they do I would like to put it on my working 2N. Any thoughts,pros , cons?
jdchet
08-22-2006 18:06:05
 Re: Zenith Carb. in reply to Richard from SE AZ, 08-21-2006 10:51:04
I don't know much about Zenith carbs, but iffn' your 2N is running nice..... .well..... ...you know the old saying!
"If it ain't broke.....don't fix it!"
JD
Tom N MS
08-21-2006 15:11:27
I have a new Zenith and 3 MS carbs and one MS copy. A good MS can't be beat. They all perform a little different and adjust out a little different. If I had known then what I do know now, I would have kept my $180 in my pocket. The Zenith ain't nuttin that special that I can see..BUT depending on the meaning of VERY reasonable you might not go wrong..
Stephen Mullen
08-21-2006 12:32:25
I recently purchased an 8N with Zenith. I am in the process of rebuilding it. It sat over the winter. I have read in some different places that for everyday use they are better because it is a more refined design??? I will find out soon a provide an update.
