Started Smoking
Paul from Michi
08-23-2006 17:53:00
I have a 52 8N which has run great for the last 4-5 years. Tonight I was mowing the yard, and all of a sudden it started smoking a lot! Smoke is a sort of white/grey color and was coming from the exhaust.
I quickly got the tractor up to the house and shut it off. It sounded like the radiator was boiling, as it was making a sound like boiling water.
After it sat for a couple of minutes, I noticed something leaking from around the manifold to exhaust clamp. It smelled like radiator coolant.
Before I start taking things apart, do you guys have any ideas/suggestions as to what I should look for?
Also, is this something a guy (me) with average mechanical skill could fix?
Thanks for all your help!
Paul
Jeff Brandt
01-05-2007 01:19:57
 Re: Started Smoking in reply to Paul from Michigan, 08-23-2006 17:53:00
I had the same problem as you and I replaced the head and gasket but still have the smoking.I guess mine is in the block.Yesterdaystractors.com is good for parts.
old
08-23-2006 19:18:38
Probably blew a head gasket, or cracked the head but most likely just the gasket. If you don't have one you need to get an FO-04 I-T manual so you will have an idea of how to fix the problem
Roger in Iowa
08-23-2006 18:24:55
Sounds like the head gasket has failed. The boiling in the radiator is compression gasses escaping into the coolant and the coolant in the exhaust causes white or gray smoke.
Get a manual and it will explain how to change gaskets. You will want to check head for cracks and block also.
You have to take the hood off but pretty straight forward from there. Critical part is re-assembly to include thoroughly cleaning of all parts and torquing of head bolts and in the proper sequence.
Good Luck,
Roger in Iowa
