Order Ford 9N Parts Online
oil leak 40 9n
RP-40-9n
08-23-2006 20:31:10
front seal leaking bad-any quick tricks? if not will i have to drop the crank to get new seals in her. thanks RP
Hobo,NC
08-24-2006 04:38:45
 Re: oil leak 40 9n in reply to RP-40-9n, 08-23-2006 20:31:10
You also will need to remove the timing cover no matter witch seal you use, inspect the crank pulley for ware. there are 2 different style aftermarket crank pulleys so ask witch one izz best for you application if it comes to that. I have some info in a web site I am werk段n on.
Colin King
08-24-2006 07:53:24
 Re: oil leak 40 9n in reply to Hobo,NC, 08-24-2006 04:38:45
That site is looking like the development of a good resource! Thanks for putting it together.
Colin, MN
Hobo,NC
08-24-2006 08:46:51
 Re: oil leak 40 9n in reply to Colin King, 08-24-2006 07:53:24
Enny one who would like to submit info I would luv to add it with a credit to the author. My problem izz take段n the time to arrange the info.
My intent izz to help along owners of the N with tips that they could normally use with a limited amount of recourses. Sum izz my experience and sum of the great tips I am picked up from of the generous members here.
Colin King
08-24-2006 09:09:32
 Re: oil leak 40 9n in reply to Hobo,NC, 08-24-2006 08:46:51
I'm not qualified to contribute (Though I hope my knowledge and experience will grow enough that I can contribute on a greater level someday.), but I've already got your site bookmarked in my N resource list. I wonder if some of Dawn's photos from Arthur would be instructive in terms of things to look for when taking things apart.
K.LaRue-VA
08-23-2006 20:57:05
First, is the front pulley loose?
I think the pulley bolt is supposed to be torqued to something like 150-ft.lbs. and the front seal actually seals on the back of the pulley. The quick/cheap fix is to make sure the crank bolt is tight and the pulley is not loose.
But, once it starts leaking, it is usually too late. The loose pulley will quickly wear out the rope or newer/better neoprene seal.
If you need to replace the front seal you DO NOT have to drop the crank. You just take the front axle stuff off, disconnect the tie rod/drag link on one side and swing the assembly out of the way so you can drop the pan. Make sure you have the transmission safely supported cause it will try to fall over on you!!! Then, remove the pan. Careful, it is cast iron and heavy!! The new seal should be fairly easy to slide in around the crank. I think the front seal actually seals on the pulley, so that may also need to be replaced if it has been run loose.
RP-40-9n
08-23-2006 22:24:27
 Re: oil leak 40 9n in reply to K.LaRue-VA, 08-23-2006 20:57:05
thanks for the help guys-i really appreciate it. RP
Jimmyjack
08-23-2006 21:19:35
Yes, use the neoprene seal, I just had a bad experience with the rope seal, and Im hoping the neoprene works better. Thanks for the tip Dan.
