Novice pulling a carb - '53 Jubilee
Rickstir
08-25-2006 06:45:56
We are going to pull the carb and clean it per suggestiions earlier. I have located a rebuild kit.
I could sure use some hints or what to look out for. I have found a rebuild kit at a dealer and will pick it up on the way home. The operation starts about 10 tomorrow morning. I have a friend who has rebuilt carbs on automobiles coming up to help. Thanks.
Dell (WA)
08-25-2006 10:20:25
 Re: Novice pulling a carb - '53 Jubilee in reply to Rickstir, 08-25-2006 06:45:56
Rickstir..... ...this is a great proceedure for ALL M/S carbs. Print it out. From the Yesterdays Tractors Research & Info side-column "Articles" maintenance subheading..... ....Dell
Rickstir
08-25-2006 13:03:32
 Re: Novice pulling a carb - '53 Jubilee in reply to Dell (WA), 08-25-2006 10:20:25
Thanks so much Dell, this will certainly help.
Same procedure..John,PA
08-25-2006 09:22:30
Your Jubilee will be about the same re-build procedure as the other N's. I just remanufactured a Jubilee carb. recently. There is a step-by-step procedure described on one of the sites about FORD TRACTORS. Off hand, I can't remember. I think it had something to do with the Smith's page. HTH John,PA
