Order Ford 8N Parts Online
Re: 8N over heat
Roger in Iowa
08-25-2006 14:33:29
Sounds like you are overfilling it to start with. You have to leave some room for expansion.
Drill an 1/8" hole. if it doesn't have one, so some water (hot) can circulate by the thermostat all the time. This will prevent the "blow" when the thermostat opens as it will open gradually as it should. It was really bad on my JD 4400 Diesel combine as the thermostat was a long ways from the cylinder head and hot water.
Do not leave the thermostat out. Once it overflows see what the level is (after cooling) and leave it there.
Roger in Iowa
