surging
novanut
08-25-2006 17:40:28
1952 8N runs for about 45 minutes to an hour then starts surging.. gone thru carb and also tried adjusting it. still surges
Dell (WA)
08-25-2006 18:42:47
 Re: surging in reply to novanut, 08-25-2006 17:40:28
Nuttzie..... ...what are you not telling us? Define surging.
Surging is almost always a governor problem but it is NOT a time related problem.
Somepeople might confuse surging with ruff-runnin. The only ruff-runnin' time related problem that matches yer timeframe is BAD IGNITION SWITCH. $10, cheep.
The roundcan ignition coil is fairly bullett-proof but that is also about a 1-hr ruff-runnin' timeframe.
You do know how to check yer governor, don't you? I check by setting engine to about 1/3 throttle and grabb the governor-to-carb throttle shaft by hand and try to "jazz-itt" for more rpms. Does it fight yer hand-jazz? Strongly or weakly? Do that check and gitt-back with the answers to questions raised..... .....respectfully, Dell
