Take a look in a Standard Ignition "illustrated Parts Guide". (Or, likely a NAPA, or other competing brand's catalog.) They show a certain ballast resistor, which is PTC, for "systems WITHOUT A STARTING BYPASS". The other option is a "Non-PTC" ballast resistor, for systems WITH A STARTING BYPASS. (I don't have the catalog at hand, I can post the part #'s later, if anyone is interested, and I HAVE explained this, and posted the part #'s before.) So, that is the key to the mystery. Engines, such as our "N's", which have no "starting bypass" tend to use PTC ballast resistors, for a HOT spark during initial cranking. Engines WITH a starting bypass (which bypasses the ballast resistor during cranking) use a NON-PTC ballast resistor. Phil, you are DEFINITELY on to something. In the past, the coils sold as "12-Volt" apparently had a primary resistance up in the 4-Ohm range, and, with these coils, "Dell's Secret Current Limiting Resistor" of 1/2 Ohm added just enough resistance to the circuit to make it easier on the coil. Now, it seems front-mount "12-Volt" coils" commonly are made with primary resistance closer to 3 Ohms, and need the added resistance of the tractors "OEM" ballast resistor to keep primary current to a safe level. Apparently, ALL requests for "what resistor to use" should include more than "it's a aftermarket 12-Volt coil", and will need to include the coil's actual primary resistance.
