TRANS FLUID
PA JOHN
05-17-2001 16:28:11
CAN ANYONE TELL ME WHAT TYPE OF FLUID IS USED FOR THE TRANSMISSION AND IS IT THE SAME FLUID THAT SUPPLIES THE PUMP FOR THE THREE POINT HITCH LIFT.
Charles
05-17-2001 19:06:09
 Re: TRANS FLUID in reply to PA JOHN, 05-17-2001 16:28:11
The oil you are looking for is a GL-1 80 90 wt mineral gear oil.
Steve(MO)
05-17-2001 17:52:32
John,
That question pops up pretty often on this board, and a spirited discussion usually follows. Click on the link below to see what Llamas and others had to say on the subject. Also, you can find other opinions by typing "transmission oil" in the search box for the archives. Personally, I use oil that conforms to specification M2C134D.
Good luck,
Steve
8NRay
05-17-2001 17:05:20
If you have a 9/2/8N it uses 90Wt hypoid and the tranny/differential/hydraulics share the same oil.
Check this link out
