Order Ford 8N Parts Online
3 point/hydraulics, 8N
RAS
02-01-2000 05:28:23
Was using my blade the other day and all of a sudden , no action on the lift. Went from working just fine to nothing. Haven't had time to take off a single bolt. Any experience as to hopefully a simple fix, or do I just need to dive in?
ZANE
02-01-2000 19:21:30
 Re: 3 point/hydraulics, 8N in reply to RAS, 02-01-2000 05:28:23
Remove the right hand inspection plate. the one with the dipstick in it. start the tractor with the pto in gear and reach in and push the long lever that goes from top to bottom forward to see if the control valve might be stuck from some gook entering it.
Also move the control handle and see of the control rod moves too forward and back. It should. If it doesn't and the lift will work by moving the control rod by hand it is possible that the cam follower pin has been worn off and there is no positon control.
Brent(AR)
02-01-2000 09:21:09
Is it possible that the PTO could have been disengaged?
Brent(AR)
