Cracked block
RFD
08-28-2006 07:09:24
First I would like to say thanks for all the help I have gotten in the past
looks like I have a small crack in the block, Where can I find someone to weld this for me In the Dallas area??
Thanks for any Ideas
RFD
08-29-2006 09:58:07
 Re: Cracked block in reply to RFD, 08-28-2006 07:09:24
Thanks for the info, headed out to get some j-b weld
LWD
08-29-2006 02:06:10
when welding cracks the most important thing is to drill a small hole at each end of the crack I like to use a 3/16 hole, weld only about 3/4 to 1 inch at a time,stop and peen until it cools to the point you can hold your hand on it,then weld some more, and repeat,,repeat. if you grind a "V" and weld carefully, you flux and cover with lead and use a air driven peening or flux hammer and the weld will not show(under the paint)
RP-40-9n
08-28-2006 15:53:53
if the crack is on the outside of the bkock, j b weld will do a great job and last forever if toy do one thing,- be suuuuu ure- its clean before applying the j b weld. RP
'41 9N..John,PA
08-28-2006 13:06:45
My '41 9N came from the factory, as was common during the WAR years, with the block welded (brazed). She just weeps a little when it is cold, but, it stops when the coolant starts warming up the block.
I thought about doing some sorta repair, but, I have decided to let it be.
Dan
08-28-2006 07:32:06
My 48 8N trailer queen has a nasty braze line on the side of the block that weeps when it is cold outside and the engine gets hot. I showed it to my FIL last night and he said he has a guy next to his shop (in Ft. Worth) that is very good at brazing cast iron. I asked about welding, and he told me since it has already been brazed you can not weld it unless you get EVERY bit of brazing out - no luck there. You will find it extremely difficult to find someone that can weld cast nowdays.
Do a research in the archives for cracked blocks and find out how to do the JB Weld repair - that is the best and easiest way to do it.
Good luck,
Dan
lonestarjeff
08-28-2006 07:22:11
RFD...depending on where the crack is, you might be able to use JB Weld instead of heat welding to close it(save alot of time & $$). Can you post a picture of the crack?
Jeff
Stumpalump
08-28-2006 19:20:13
 Re: Cracked block in reply to lonestarjeff, 08-28-2006 07:22:11
For what it's worth, I bought a small pack of welding rods that were labeled "for machinable cast iron" from TSC. They were used on a jeep steering box and it held for years with 36" tires. I allways thought I could use them on a block someday.
