Tony in IN-----Limiter Chain Setup
8N'r
08-30-2006 04:47:16
Hi Tony---saw you commenting on some topics today--if you are the Tony that posted a pic of your limiter chain set up in July on the other site, please post one over here---that was the slickest setup I have seen---converted mine over and works easier and faster than what I had before---I could paste one here, but it is your idea--I think some of the other"s would think it is a good idea as well!!---Thanks in Advance---Tim (WI)
Tony in IN
08-30-2006 14:40:43
 Re: Tony in IN-----Limiter Chain Setup in reply to 8N'r, 08-30-2006 04:47:16
Here it is!
I thought it was a good set up for keeping the mower from dropping too much, easier to do since it doesn't require cutting and welding. Basically these hooks replace the fabricated brakets that are usually described to hold the chains at a set length.
third party image
I can't post a picture with the mower attached because the 8 N won't start at present.
Tony in IN
