Order Ford 9N Parts Online
carb 9n
RP-40-9n
08-31-2006 10:18:57
on 40 9n when i shut her down, if i dont turn the fuel off. the gas continues to run into the engine. is this normal or do i need a carb rebuild? RP
Dell (WA)
08-31-2006 10:51:59
 Re: carb 9n in reply to RP-40-9n, 08-31-2006 10:18:57
RP..... ..very common, its tuff to turn OFF GRAVITY. Can be caused by sticky float valve or piece of crud caught in float valve ...or... fuelfloat that has lost its floatability (sprung a leak).
You should ALWAYS TURNOFF yer under the fueltank valve when yer thru for the day. Even yer Ford OWNERS manual recommends it. (isn't than amazing?)..... ...respectfully, Dell
Dan
08-31-2006 10:30:50
Yes, and yes.
A rebuild "may" stop this - for a time. However, this is extremely common on our N Series tractors and everyone turns theirs off after use - it is just habit.
Recently I have seen an electronic shut-off device that does this for you every time you stop the tractor. I thought this was pretty slick, but not sure of how durable they are.
HTH,
Dan
souNdguy
08-31-2006 11:50:11
 Re: carb 9n in reply to Dan, 08-31-2006 10:30:50
Lotsa diesels use fuel shutoff solenoids..
Soundguy
