GREAT post, Phil! I would think lots of folks would have jumped on this with replies, but sometimes I think guys like to remain "in the dark" about what really goes on in these simple ignition systems, and keep buying coils! To add to the coil confusion, I had a few minutes the other day, in TSC, and was looking at front-mount coils. They had two, lying on the bottom shelf of the display rack, with the staples pulled loose in the "clamshell" packs, so who knows if they had been switched between packs by folks looking at them. There were NO markings on the actual coils. The packages were marked as follows: "0238001 IG COIL 8N to #263843 1939-1950" (NO Volts listed, NO mention it will also fit 9N and 2N.) "0236588 PKG IG Coil Ford" (NO Volts listed, or ANY mention of what it fits, other than Ford.) I found the hangers where the coils should have been hanging, and here is how they were labelled: "FD 2N 9N Coil 12V 0238001" (The PACKAGE only says "8N", the mark on the display hanger says 2N 9N, and OMITS 8N, but at least the Volts are given.) The other display hanger says: "CX 6V 8N 2N 9N 0236588" So, it's about as clear as mud... the display hangers are poorly labelled, the clamshell packs have been opened, and the contents COULD have gotten mixed around, and there are NO markings on the actual coils, to verify this. So, it's no wonder folks have NO idea of what coil they have just purchased! I will take a DVM along next time I go there, and, hopefully get the manager's permission toh measure the coils' resistances, to see what they are actually selling these days. Also, I will get the Standard Ignition ballast resistor specs we talked about a few days ago posted this weekend.
