8 N lift question
road_trot
09-03-2006 22:15:31
My father-in-law is looking to purchase an 8 N, But.
The lift does not go up unless you hold the little lever under the seat all the way down.
What is involved to fix that so you can use the lift properly and not have to hold the little lever down.
The PTO on the back engages with no problems
Empennage
09-04-2006 06:12:52
 Re: 8 N lift question in reply to road_trot, 09-03-2006 22:15:31
The little lever is the draft control lever and should be up or "vertical". Did you try it in the up position?
