Ever been on a riding mower? You know how you can engage the blade of the mower deck seperate from everything else? Then the blade is spinning, regardless of what you do with the transmission and transmission clutch. That is live pto. The device (a mower deck in this case) driven by the pto is connected to the engine directly, and seperate from everything else. In the case of an N tractor, the pto is connected to the main transmission, and not the engine. Push in the clutch, and the pto stops spinning. Which makes it darn hard to work with when manuevering around slowly. You can't creep up on thick grass on an N because every time you slip the clutch to creep forward, you slow down the pto shaft. Unlike the live pto the riding mower has, which allows you to slip the driving clutch, while spinning the pto driven mower deck fully. Can you imagine how annoying and difficult mowing with that lawn tractor would be if every time you pushed in the clutch the mower deck shut down? The only reason the N isn't quite that annoying is it's got a lot of power. That's the main difference between live vs non-live pto's. In the case of the N, and many others, there is a secondary issue with the non-live pto. Two actually. One is that the pto is driven off the output shaft of the transmission. This means that the tractor must be in neutral or moving for the pto shaft to spin. It also means that if the pto shaft is spinning, the tractor is being moved, or must be in neutral to stay still. Pushing in the clutch doesn't matter, the engine is out of the picture here. You would need to be in neutral to seperate the pto shaft from the driveshaft. Hence the nasty habit of bush hogs shoving tractors around by their rotational inertia, and the need for an overruning clutch. This prevents the attachment from pushing the tractor around through the pto shaft. Another annoying aspect of the N is that the hydraulics are driven off that pto shaft. So every time you push in the clutch, the hydraulics are dead. So when you're pushing snow out of the driveway and across the road, you have to wait in neutral with the clutch out to lift the blade, then shift again, and drive back. It can make life rather exciting and complex some times.
