12 volt conversion
Paul Twehues
09-05-2006 17:32:24
I bought a 12 volt conversion kit from Yesterday's Tractor for a Ford 8n with a side distributor, but I can't figure out how the alternator brackets are suppose to work. The "instructions" don't mention the brackets and I send an e-mail to Yesteray's Tractor but received no reply. The lower bracket (the one I can't figure out how to mount)is the same one as pictured in the ad for part #8NL10300ALT. Can any one tell me how to mount the alternator?
Hobo,NC
09-05-2006 17:54:31
 Re: 12 volt conversion in reply to Paul Twehues, 09-05-2006 17:32:24
One bracket bolts to the original gennie bracket and the long'in bolts to it and to the little tab on the water pump that the top gennie bolted to and adjusted the belt and then the short one to that and then to the top bolt on the alt. really a good set up but confuse'in ain't it.
Iffin you kin not figger it out call me 919-776-8821, one day I'm gonna take a pix of the brackets.
