Clutch
Nova
05-18-2001 18:28:28
More Help needed....Cleaned flywheel, but did not grind. Replaced pilot bearing and throwout bearing. Replaced cluth(old one not really that bad)Cleaned pressure plate but did not replace.
Now I have a VERY weak pedal, doesn't seam to being pushing the pressure plate. Have not tried putting in gear yet, but doesn't feel right.....any ideas???
Michael Az
05-19-2001 07:42:58
 Re: Clutch in reply to Nova, 05-18-2001 18:28:28
third party image
Something I thought I would throw out. I run into same symptoms a year ago, but I had replaced the pressure plate. Found out the pressure plate was the right part number, but they had used fingers for a car or pickup which are a little too long and doesn't have enough clearence for the clutch shaft. My help someone else though----- Michael
Jim
05-19-2001 06:33:24
Nova
Two additional questions for you.
1. Someone awhile back had a broken/sheared shaft (p/n 7510) which occurred inside the case bushing. He didn't see it until after scratching his head for many a day also. Is the shaft broke?
2. If you used the intallation method in the FO-4 manual for aligning the clutch splines on assembly. DID YOU REMOVE THE WOODEN WEDGES from the pressure plate release level arms?
Just asking? Jim
bj/8N/mt
05-19-2001 06:06:58
There are really only a few possibilities. If the clutch linkage is hooked up like the pictures in the F O 4 manual; if the throwout bearing is the correct one--right length from fork to bearing face; and there is no or very little resistance to the clutch pedal then it about has to be that the pressure plate springs have somehow lost their tension. You did say you reused the old pressure plate. Although there is a proceedure for adjustment of the release fingers it requires a jig and I have always found it easier to just have a clutch shop do it or get a rebuilt pressure plate. I guess it would be possible to get the release fork behind the throw out bearing but that shouldn't cause lack of pedal feel just more pedal travel. It might also be possible to get a clutch disc with dramatically thinner friction surfaces but again that is pretty far beyond the realm of the likely.
Your mileage may vary
Dell (WA)
05-18-2001 21:44:18
Nova..... ..I can't remember 'xactly but the N-clutch plate is an "offset" design where the central splined bush is not centered in the rotational plane of the clutch friction material. I can't remember if'n there is a "this side out" kind of warning. But if'n you put the wrong side out, you could find your clutch pedal not traveling the needed distance to release the clutch pressure plate. You might want to further investigate this possibility..... .Dell
Nova
05-19-2001 04:30:29
 Re: Re: Clutch in reply to Dell (WA), 05-18-2001 21:44:18
I have split the tractor back apart, Clutch disc is on the correct way. I did not find anything I see wrong. I MUST admit, I'm confused! (but sometimes thats not hard to do) What the Hel1 am I missing?
Fast Ed Ohio
05-18-2001 23:08:02
Put a cluch plate in backswards on a 56 plymouth once, never herd the end of it. ( it was my car ). Dont ask. I was a 16 year old kid at the time it taught me to do things right the first time or they will come back to haunt you.
8NRay
05-18-2001 20:42:50
Check the bottom of the page of this link.
Did you check the clutch finger height?
PAUL8N
05-18-2001 18:31:17
NOT TO BE SMART BUTT, BUT DID YOU ADJUST IT, ONE INCH PLAY FROM WHAT I HAVE READ. THATS WHY ITS ONLY MY .01 WORTH.
Nova
05-18-2001 18:36:28
 Re: Re: Clutch in reply to PAUL8N, 05-18-2001 18:31:17
Adjust the pedal? Clutch?
Nova
05-18-2001 18:30:12
I also have tried to adjust the pedal..... ..not alot of help
