Order Ford 9N Parts Online
40 9n needhelp
RP-40-9n
09-06-2006 17:25:40
tractor runs perfect, but my very good oil pressure has vanished. what steps do i take to diagnose this problem? i think its still gettin oil cause the valves aint talkin to me. much appreciated RP
Sean (TX)
09-07-2006 15:21:05
 Re: 40 9n needhelp in reply to RP-40-9n, 09-06-2006 17:25:40
The carb rebuild got you running again?
RP-40-9n
09-07-2006 17:50:26
 Re: 40 9n needhelp in reply to Sean (TX), 09-07-2006 15:21:05
runnin like a new tractor. RP
RP-40-9n
09-06-2006 18:53:05
thanks guys, could it be possible that the guage went bad, or it lost its prime> thanks again RP
ZANE
09-06-2006 17:52:18
Don't run it any at all if it has no oil pressure.
The valves aren't going to tell you anything about oil pressure in the N engine since it does not have hydraulic lifters. Solid lifters for the N engine.
Take the drain plug out of the pan and see if the pick up tube is loose from the pump. If you can wiggle it that is going to be the problem.
Zane
OT: SIR ZANE..John,PA
09-06-2006 18:52:46
 Re: 40 9n needhelp in reply to ZANE, 09-06-2006 17:52:18
Sorry about the e-mail that I transmitted your way the other nite. JUST HAD ENOUGH.
Now they have moved me to the lower "CELL". Well, it will be a lot warmer over the winter. Judge said "still community service". All I have to do is to make sure the igniters keep working on the boiler. Plus, minimum wages and "full time, PART TIME work. Between the hours of 11PM to 7AM ET. Thanks ZANE, just for listening.
John D.
The coldest time of day is always 7AM ET. The warmest is 7PM ET. Mostly.
old
09-06-2006 17:51:02
Drain the oil and then reach up and see if you can move the oil pickup. If it moves then your problem is the oil pickup tube has come loose and will need fixed and or replaced. Common problem
