distributor play
Ozark kurt
09-06-2006 18:28:02
Should the shaft of the distributor have a little play? Mine can wiggle in and out about 1/16 of an inch. I am wondering if this is why I am getting brass shavings inside the cap. Also the points need to be cleaned after every other use.
Dan (NYC)
09-06-2006 19:20:39
 Re: distributor play in reply to Ozark kurt, 09-06-2006 18:28:02
there - are 2 bushings that are probably worn. they are press fit and easy to change. The brass filings are probably from the rotor touching 1 or more of the contacts due to your worn bushings. THT
Dan
Jerry Hope
09-06-2006 23:09:13
 Re: distributor play in reply to Dan (NYC), 09-06-2006 19:20:39
Where can we get those bushings ?? Also no roblem to press in, but how do we reove the old ones ??
