Order Ford 8N Parts Online
8N Starter Installation
PartTimer
09-09-2006 12:53:44
I can't get the dang starter back in. I have removed the pet-cok from the block to give more room to no avail. What is the secret - I've held my mouth in every position immaginable and still no luck.
Thanks!
Ross Pugh(NC)
09-09-2006 16:03:55
 Re: 8N Starter Installation in reply to PartTimer, 09-09-2006 12:53:44
Part timer, time to go full time, do like Bruce said take a grinder and grind the starter hole opening at about 2:00 if it was a clock face and make the hole egg shaped and it will make this installation and any further starter work later much easier and ye will appreciate it the nest time ye have to remove it. There is one site that has a picture of the ground hole but this site won't let me tell the name of it. It won't post it's name.
mush
09-09-2006 13:31:03
it help's a great deal to remove the oil filter housing.
starter will pop right in then.
Bruce (VA)
09-09-2006 13:30:41
Try removing both bolts in the oil filter canister; no need to remove the canister, because the extra 1/2 in of play helps. Keep the starter body as close to the block as you can; removing the petcock was a wise move. Are you using the new bendix? The new style bendix is a bit bigger; get your grinder out & grind out the hole in the bell housing at the 2 o'clock position. Don't grind out the bolt hole!
Russ SoCal
09-10-2006 10:19:28
 Re: 8N Starter Installation in reply to Bruce (VA), 09-09-2006 13:30:41
third party image
PartTimer
09-10-2006 11:58:18
 Re: 8N Starter Installation in reply to Russ SoCal, 09-10-2006 10:19:28
Thanks a bunch guys for the replies - especially the pic of the grinding spot... worked like a charm!
