Ron..... ..you write..... "stays up at least partailly. for 30 minutes. If the tractor is not really hot it will take almost an hour to drift down"..... ..It should be intuitively obvious HOT-OIL is thiner and leaks faster than thicker COLD-OIL. 30-min leakdown is almost "braggin' rights"; altho there are reports of 8-hr leakdowns for rebuilt hydraulics. Change yer oil, won't hurt 'nuttin'. Ford/New Holland recommends spec: M2C-134D hydro-tranny oil. Some claim that this is too thin for old leaky hydraulic systems. You can also use the 1939 recommended 90wt mineral gear oil (iff'n you can find it) Modern GL-1 is close approximation. do NOT use modern multi-wt GL-4 or GL-5 as they have "additives" that are perported to be "un-friendly" to yellow metal. 3-drains and 1-fill'em-up by the tranny shifter. Drain the square diffy plug first as it peees with better accuracy into yer 10-gal pan. Then drain the 3" tranny plug. Finally drain the 3" hydro-pump plug. Fill with 5-gal of hydro-tranny oil. DO NOT OVERFILL as the oil will splash out yer axle trumpet seals and greese yer brakes. Not good. Correct hydro-tranny oil level is best set by pulling the 6'oclock (bottom) bolt of the 6" round dipstick plate behind yer right heel and lettin' any OVERFILL drain/dribble down the side of yer tranny housing. Now check yer dipstick level, that is the correct level, not the engraved mark. Understand?..... ...Dell
