Steering box is rebuilt
Dan
09-10-2006 11:40:27
third party image
I finished up my steering box on my 1948 8N I am working on this morning. This has been a full rebuild replacing everything that can be replaced. It has new steering sector bushings I reamed myself with a brake hone, I replaced the nylon bearings with good steel bearings and cups, TWO steering sector oil seals on each side, new upper steering tube bearing and dust seals, and new 3/4" jamb nuts and lock washers for the sector arms. All backlash was adjusted out thanks to the new bushings.
I had about 2"-3" of free play in the steering wheels before it affected the steering sector shafts, now it is almost immediate response. All bolts and holes have been cleaned up with a tap and die. I filled the box with 2 tubes of John Deere cornhead grease when it was all put back together. I wire wheeled the three layers of paint off the box this morning, and applied three coats of TSC New Holland Red enamel paint to finish it off. Sure turns nice and smooth now.
It will sure be nice to drive across the pasture without the wheels flapping all over the place :-) Hydraulics are next.
Dan
SEBE TX
09-10-2006 14:41:52
 Re: Steering box is rebuilt in reply to Dan, 09-10-2006 11:40:27
Dan- Did you drive the sector bushings out with a bushing driver and replace them the same way, or did you use a press? How did you replace the bottom bearing cone(race)? There has got to be a trick as I cannot even get my hand in there, not to mention the angle. Glad you got'er done.
Dan
09-10-2006 17:16:09
 Re: Steering box is rebuilt in reply to SEBE TX, 09-10-2006 14:41:52
I pounded out the sector bushings with my Harbor Freight bushing driver. I pushed both out one side, then put the new ones in on each side to the specs listed in the I&T manual. I used a small brake hone to ream out the bushings until the steering sector shafts "just" fit smoothly.
I replaced the bottom bushing by pounding the round steel blank you see when you flip the steering box over inward and in doing so pushed the nylon bushing into the center of the box (yours may be the correct steel bearing race). I pounded the round blank back into place from the top after cleaning the area real well. Then I used a long brass drift to pound the steel bearing race into the recess for it. The roller bearing just floats in this race with the downward pressure of the worn gear shaft the only thing that keeps it in place.
HTH,
Dan
Jimmyjack
09-10-2006 14:12:49
Good job Dan, you went a little further than I had to, but the cornhead grease seems to be great. No leaks, and smooth as silk. I had an extra tube, left it lay on my bench, and sun hit it through window. What a mess. Two tube is all you need.
Dan
09-10-2006 17:53:31
 Re: Steering box is rebuilt in reply to Jimmyjack, 09-10-2006 14:12:49
I had a partial tube left over from when I rebuilt my NAA (Rustbucket) steering box. When I lifted the grease gun up green liquid leaked all over the place from my shelf to my workbench - it was a mess indeed. All the tubes I had on my shelf had the same green liquid floating on top I had to drain. Hope I didn't need this liquid :-)
Dan
