8 N FORDTRACTOR
BRIAN DALLAS
09-10-2006 15:01:53
HOW TO REMOVE HYDROULICS PUMP FROM 8N TRACTOR
kennymo
09-11-2006 05:47:54
 Re: 8 N FORDTRACTOR in reply to BRIAN DALLAS, 09-10-2006 15:01:53
hobo. some early 8ns still had fork mecanism to controlvalve. km
Joe(IN)
09-11-2006 09:16:21
 Re: 8 N FORDTRACTOR in reply to kennymo, 09-11-2006 05:47:54
I beg to differ. One of the key reasons for the birth of the 8N was the necessity to distance the design of the hydraulic system on the Ford tractors from Harry Ferguson"s patented design after they parted company. No 8N was EVER built with the fork type draft control only hydraulic system that the 9N/2N"s had. If you"ve found one, someone has swapped the earlier hydraulics into it.
JimNC
09-10-2006 15:19:10
4 bolts, pull pto shaft out. Unbolt pump, pry gasket loose, pump falls out.
Jim
Tom N MS
09-10-2006 17:48:19
 Re: 8 N FORDTRACTOR in reply to JimNC, 09-10-2006 15:19:10
What about disconnecting the quadrant fork from the control valve???
Hobo,NC
09-10-2006 18:23:09
 Re: 8 N FORDTRACTOR in reply to Tom N MS, 09-10-2006 17:48:19
Topic: 8 N FORDTRACTOR, does not have to be removed like a 2N/9N
Tom N MS
09-10-2006 18:47:09
 Re: 8 N FORDTRACTOR in reply to Hobo,NC, 09-10-2006 18:23:09
Thanks, I had read that they were different but I guess in my feeble mind I thought the basic setup was the same just shaped different..How does it connect??
phil_in_WA
09-10-2006 18:57:00
 Re: 8 N FORDTRACTOR in reply to Tom N MS, 09-10-2006 18:47:09
Ball end of the control arm fits into a cup on the valve control pivot arm.
You do have to reach in through the inspection port to align the two unless you get amazingly lucky..
Finaly a questions I can answer. THe one part of my 8N I've rebuilt
Tom N MS
09-10-2006 19:17:19
 Re: 8 N FORDTRACTOR in reply to phil_in_WA, 09-10-2006 18:57:00
Thanks,I did not know how that was setup on the 8N.
