9N Clutch Problem
Help
Paul
05-19-2001 10:18:08
Started the 9N this morning - the clutch would not release - I could not put it in gear - the linkage looks fine and is operating properly - Ran the tractor last week - might have slightly experience that same problem, but them it released(?) and everything operated OK. Is the pressure plate stuck to the clutch disk? How do I fix - Any advise?
Paul
05-20-2001 14:13:16
 Re: 9N Clutch Problem - Help in reply to Paul, 05-19-2001 10:18:08
Thanks - your suggestions plus archives helped solve the problem - fixed it today. Also cut a 2x4 to fit between seat and depressed clutch peddle....that will be standard procedure when it's shut off from now on. Thanks again.
Salmoneye
05-19-2001 10:41:18
Block the clutch pedal down and put it in fourth with the engine off.
Get a helper and each of you grab onto a rear wheel and rock the tractor back and forth as violently as you can :-).
Should free up the clutch.
From now on I suggest blocking the clutch pedal down after you put her away for the night...
bj/8N/mt
05-19-2001 10:31:13
What you have is a not un common N series event. You have it nailed, the clutch disc is stuck to the fly wheel. If you check the archives there are several rodeo cowboy ways to break it loose. I got lucky once with a socket on the crank nut, the rear tires blocked, and a helper holding the clutch and brakes with the trans in fourth gear. I wouldn't use any cheater as I can imagine a lot of things you can break this way.
Your mileage may vary
