battery
anchises
09-12-2006 15:34:25
what 12 volt battery would be recomended for an 8n?
i have looked through the archives, but quit after about 10 pages.
i did not find anything there.
i have access to napa, walmart, tractor supply and several auto parts stores.
thanks
dbnga
09-13-2006 06:25:25
 Re: battery in reply to anchises, 09-12-2006 15:34:25
Champion batteries from Walmart have proved disappointing to me over the years....I now use Autozone battery in truck. When battery fails in tractor I will probably check theirs out for a replacement.
Hobo,NC
09-13-2006 04:52:29
A Interstate group 35 izz a direct replacment fer a group 1
1) L-8 7/8 W-6 7/8 H-8 3/4
35) L-9" W-6 7/8 H-8 3/4
"Tip" If you have a OEM Top hold down make sure the top hold down does not contact the battery post, on a 8N I trim a little cut out on the top hold down just to be on the saft side. I have no idea were the others come up with their bats group size as being the same cuzz they aint.
Ha Hobo-
09-13-2006 08:10:53
 Re: battery in reply to Hobo,NC, 09-13-2006 04:52:29
Those group 1 numbers are WRONG!
Hobo,NC
09-13-2006 08:53:40
 Re: battery in reply to Ha Hobo-, 09-13-2006 08:10:53
Not by my interstate bat catalog, not by a group 1 and a 35 I have set'in here on the floor, actually a group 1 izz 9" long and the 35 izz exactly the same size. The only difference izz the G-1 has the post staggered on the 35 to post are on the same side. The G-1 post are set in from the side ‘bout a 1” , the 35 post are out near the sides that’s why I recommend you timmg the top frame a little to be safe. The 35 my be a tad higher 1/8", I kin post a pix if need be of the 2 bats and the 35 installed in a N, I do not need to read the BCI cuzz I have’em rite cheer in front of me.
murnga
09-12-2006 16:16:40
A group 22f battery is the same size as the group 1 6v. You do not need a high amp 6v to start an 8n. I think the modern day group 45 will work also.
Ken S.
09-12-2006 17:04:31
 Re: battery in reply to murnga, 09-12-2006 16:16:40
anchises, you deside which is closest to Group 1
Group 1----- L=9 1/8" W=7 1/8" H=9 3/8"
Group 25/35-L=9 1/16" W=6 7/8" H=8 7/8"
Group 22f----L=9 1/2" W=6 7/8" H=8 5/16"
Group 45----L=9 7/16" W=5 1/2" H=8 15/16"
Ken S.
09-12-2006 16:16:02
Group 25 is the 12V closest to the physical size of the original 6V. CCA isn't really an issue, any 12V battery will have far more CCA's than a N will ever need.
old
09-12-2006 15:58:18
I use wal mart batterys in my tractors all the time. As far as what battery the biggest CCA you can find that will fit in is how I do it. Sorry I don't remember the number of the battery, but I use the same size battery in most of my tractors and I have more tractors then I do batterys
gahorN
09-12-2006 18:11:43
 Re: battery in reply to old, 09-12-2006 15:58:18
WalMart doesn't make batteries. They just sell others batteries, and run locals out of business then raise their prices to cover the losses of some other WalMart that's undercutting local businesses to run them out of business.....
Hobo,NC
09-13-2006 15:53:03
 Re: battery in reply to gahorN, 09-12-2006 18:11:43
You Go Boy Ats rite Zackly the way they werk here, cept they are a hang out fer our illegal aliens who our guvmint welcomes, I may have just seen the lite the Guvmint izz in on the deal. They give’em free money so they kin go to Wall-Mart and spend it, put the local small man on hiz knees.
dan hill
09-13-2006 02:50:43
May have a lot to do with price.Local Oil DRI prices Walmart 3.60 Auto parts store 7.50 Ace Hardware 10.99.Where would you buy it?
gahorN
09-12-2006 18:11:33
dixon
09-12-2006 22:16:02
 Re: battery in reply to gahorN, 09-12-2006 18:11:33
easy now!!!!! !!!
