coulter wheel depth
PhilipIN
09-13-2006 08:43:12
third party image
How do you determine the depth of the coulter wheel? Do you want it as deep as the plow bottom? Thank you, Philip.
ZANE
09-13-2006 11:49:19
 Re: coulter wheel depth in reply to PhilipIN, 09-13-2006 08:43:12
Throw them away! They are a lot more trouble than they are worth and if the ground has a lot of trash on it they will clog up the plow I guarentee you.
Zane
PhilipIN
09-14-2006 12:52:32
 Re: coulter wheel depth in reply to ZANE, 09-13-2006 11:49:19
Thank you for the input Dell and Zane. Our local club has plow day every fall, and this is the only time I really get out and plow. For the past four years I have been the only Ford out there, but I really enjoy it. I have been using my Dads old Ford 2-14" with no furrow wheel and no coulters, so I feel as though I have always been missing out. I bought this Ford 2-12" trip plow minus one coulter wheel this summer for $100 from an employee here at work. I have spent months for the missing coulter wheel, and finally found it!!! You may be right Zane, but I am excited to try my new 2-12" plow this fall with coulters and furrow wheel in place! The early 1950 8N should really throw dirt now! Philip.
Dell (WA)
09-13-2006 09:23:11
Phillip..... ...principle job of the coulter wheel is to cut the sod roots. Usually 3-inches is sufficent. Most moldboard plows run about 6-in deep. tip: plow fast and NO RUST (high drag/draft)
The 8N-Ford owners manual has excellent instructions on how to set-up a plow (12-pages) $8, cheap. Gittcha one!!!
Ford coulter instructions say: "Rolling coulters are used to cut trash, roots, reduce draft, and to leave a uniform furrow wall. The coulters should be set about 1/2 the plowing depth on average soils. In soils where plow penetration is difficult, it may be necessary to raise the coulters. Coulters should be sharp to lessen draft, leave a uniform furrow wall, and reduce the tendicy to ride the plow out of the ground." ..... ...HTH, Dell
