too much noise
RP-40-9n
09-16-2006 18:42:35
does any body know any way to quieten down the grind in these old tractor tranny and rears. RP
Dell (WA)
09-16-2006 19:10:38
 Re: too much noise in reply to RP-40-9n, 09-16-2006 18:42:35
RP..... ..yep, replace yer bearings. Simple, eh?
Check yer hydro-tranny oil level. 90wt gearoil will be quieter than 60wt M2C-134D.
Howsomevers, SQUARE-CUT GEARS are inherently noisy.
You indicate that your tractor is a 9N from your signature. In 1942, Ford changed the tranny front main gear from spur-gear to helical gears for quieter and stronger operation. They are RETROFIT able p/n: 2N-7017A (main-shaft) and 2N-7113A (counter-shaft) For service, use the helical gears. Trannys with helix gears will have HX stamped on the tranny case flange. I have NO KNOWLEDGE wheather the helix gear parts are still available..... ...Dell
Cargocult
09-16-2006 18:57:50
Depends. If U wanna sell it...Fill it with saw-dust! Will definitely quiet it down 4 awhile.
Ross Pugh(NC)
09-17-2006 16:40:32
 Re: too much noise/NOTE TO SELF in reply to Cargocult , 09-16-2006 18:57:50
NOTE TO SELF: Self, DO NOT EVER buy a used tractor from cargocult!!!
duey
09-17-2006 13:03:23
 Re: too much noise in reply to Cargocult , 09-16-2006 18:57:50
Tsk, Tsk, TSK!!! No honor among thieves????!?!
You might consider a new TV program,
TURN THAT TRACTOR!
duey :-)
