The Ballast Saga
Phil (NJ,Az,Sas
09-17-2006 03:07:42
I have been unable to obtain a “true” Ballast ignition resistor. The Master Catalog of “Standard Motor Products” clearly identifies the RU-11 as Ballast with thermal resistance of .50-60 to 1.75 Ohms. The product is NOT as described (its “Bogus” .55 period) and will damage a vintage coil. The Automotive devices, made in Mexico, are FIXED resistances. The device resistance is stamped on the electrical connector. The vendor’s Napa, Borg Warner, Standard use a “Cross Reference” that is not consistent with each other or to themselves. It is not very helpful to the shade-tree mechanic when vendors are selling “Bogus” Product.
The only Coils that use or need a Ballast type resistor are the “ N-Front Mount” and other vintage coils that require current limited to ~ 3 Amps.
The two (2) N- OEM Ballast resistors that I have are both correct (true) but they are time dated (old). I will obtain a sampling to test when I get back to Arizona next month. I think a vendor in TN was selling just the OEM Ballast for ~ $6.00 and buying in Canada is expensive and may not be a true representative of the Product (third party vendors).
If you want to mess with 12 Volt conversions you need to measure and verify the Ignition resistors.
JMHO
Bob
09-17-2006 07:32:56
 Re: The Ballast Saga in reply to Phil (NJ,Az,Sask), 09-17-2006 03:07:42
Could someone have mixed up an RU-10 and an RU-11 between their respective boxes... they LOOK the same, but one is PTC, and the other is not. There's no part # ON the units, right?
Phil (NJ,AZ,Sask)
09-17-2006 13:03:45
 Re: The Ballast Saga in reply to Bob, 09-17-2006 07:32:56
BOB, No they were not mixed-up. I spent 1 1/2 hrs going from Vendor to Vendor (Regina.SK) until I reached the "National" Warehouse. The RU-10 is marked correctly 1.8 (ohms) and the RU-11 is marked correctly .55 but its NOT thermal and its also .55 @ 3 amps.
The Standard's RU-4 that I bought in Minot, ND has a bar-code (on box) with "Made in USA" #91769-02253-2. The RU-11 I bought in Canada has the same type of Bar-code (on box) but with "Assembled in Mexico" #91769-02237-2
It is possible that Canada is selling a product that is not "Standard Motor Products".
Regards,
Dell (WA)
09-17-2006 06:58:57
Phill..... ..thanks for follow-up. Keep working the resistor problem for 12-volt squarecan ignition coil installation..... ..Dell
