Clutch won't release all the time
arctodus
09-18-2006 10:09:35
Any ideas as to why my clutch on the old 9n won't release all the time? I have to pump it in order to get it to release. Anything other than a complete clutch replacement will fix it?
Thanks
arctodus
09-19-2006 09:46:43
 Re: Clutch won't release all the time in reply to arctodus, 09-18-2006 10:09:35
Thanks for the GREAT information I will give that a try this weekend.
Thanks
arctodus
MikeRW
09-18-2006 12:17:12
I used the method of spraying brake cleaner into the starter hole as Dell mentioned and haven't had my clutch stick in over a year now.
Dell (WA)
09-18-2006 10:40:45
arctodus..... ...what Bob said..... .go on a drive and "SLIP" yer clutch abunch to "polish" enny rust on the clutch-plate and flywheel.
The sliding spline of the clutch-plate should be squeeky clean. Sometimes it gitts greesed and sticky. Heres a sometimes helpful techinque. (beats doing the dreaded tractor split) Take a full can of brake-cleaner and bent the straw into a "U" configuration. Remove yer starter motor (give the starter bendix a wash-out while its handy) and squirt yer clutch spline area as best you can. Use lotta squirt and letter drain out the cotterkey holes. Don't worry iff'n yer plastic straw drops off, it won't hurt 'nuttin'..... ..Dell
Bob Jones
09-18-2006 10:26:54
It's due to corrosion and oil leaks. An easy fix is to place a small wooden block between the petal and stop when ever it is parked and not running.
